CAS (Cam Angle Sensor) BP4W Motor
Posted: Sun Oct 11, 2015 6:32 pm
CAS, CAZ, CASH (you know who you are) for the BP4W are not all the same.
For those who don't know I'm running a Haltech PS100. This year, since about May the car has been having an intermittent miss issue that developed at high RPM's after a time of heavy track use. The miss would progressively get worse until the car could only be drĂven below 4,650 RPM. Changing the Cam Angle Sensor (CAS) would see the issue go away only to develop again after some high loads at the track. The failed sensors could be put into another NB and have no issues.
So on the dyno the failed sensors have been tested with all the filtering options available but a failed sensor can never be made to run in my car again, but they work fine in other cars. Therefore, it would appear to be on the surface a Haltech specific issue, not the full story!
Mazda have superseded the CAS part number BP4W-18-230 with ZJ10-18-221. No for the kicker, the new part number (ZJ10-18-221) is the one the eventually fails whereas the BP4W-18-230 part number has only failed once and was replaced by the new part number in May! So it would appear that the miss COULD be a combination between the PS1000 and the new part number. Haltech have been contacted to discuss the issue and hopefully there will be a long term fix. However for me I need to stick with the old part number.
This has been a very frustrating problem and it is good to have an explanation, it is not a solution but a very large step in the right direction. Now people could attempt to lay blame in lots of different places, that is not the purpose of this post. The purpose is to help others if they have a similar issue.
To test the theory above I have 3 CAS's from different sources, OEM (old part), MX5 Mania and Repco. If the OEM fails at WTAC I will swap it out for a different one and see what happens.
1. J5T23181
DSCN2803 by Eipeip, on Flickr
2. ZJ10-18-221 (never to be used again)
DSCN2804 by Eipeip, on Flickr
3. J5T30772 (Sold by Repco/Supercheap RAE part no SC271)
DSCN2807 by Eipeip, on Flickr
4. J5T30773 (Sold by MX5 Mania)
DSCN2805 by Eipeip, on Flickr
1. J5T23181
