NB Third brake light and LED bulb
Posted: Wed Sep 30, 2015 6:09 pm
by slipshot
Chaps
Any idea why whatever LED bulb I put in the third brake light refuses to work (2003 NB)? The standard bulb works fine. I replace with it a LED version and none of them work? I'm baffled as to why this would be the case unless there is something I don;t know.
I've replaced my rear indicators with LED bulbs and a LED corrected relay that works fine, but have no idea why the third light is not working?
And does this extend to the other main brake and sidelights/tail too?
Thanks
Andy
Re: NB Third brake light and LED bulb
Posted: Wed Sep 30, 2015 6:55 pm
by beavis
Tried reversing the polarity of the wires?
Posted: Wed Sep 30, 2015 7:13 pm
by slipshot
Flipped the bulb around - on every one too... this one bugging me!
Posted: Thu Oct 01, 2015 8:19 am
by manga_blue
Sounds like you're not getting a decent contact between the new globe and the socket. Try cleaning the new contacts with an electronics cleaner and polishing up the old contacts in the globe holder. I don't know if it's a bayonet style plug in the NB or not. If it is then check the length on the bulb from the locating pins to the bottom of the contact - it may be too short, especially if the contact plate in the globe holder doesn't move up and down freely.
Posted: Thu Oct 01, 2015 9:52 am
by smack
FYI - Flipping the bulb won't work for polarity because of the socket design (bayonet style if I remember correctly), you'd have to swap + and - wires to test polarity.
Posted: Thu Oct 01, 2015 10:23 am
by slipshot
smack wrote:FYI - Flipping the bulb won't work for polarity because of the socket design (bayonet style if I remember correctly), you'd have to swap + and - wires to test polarity.
That makes sense and it had not occurred to me but thanks for pointing it out. Need to have a look at this closer and see what I can find...
Posted: Fri Oct 02, 2015 12:29 am
by beavis
hence, why i did say
wires
Posted: Wed Oct 07, 2015 2:51 pm
by slipshot
Thanks you chaps - my bad, and a good lesson in actually reading what's written. Thank you all
