So about a year ago I installed an Innovate Air/Fuel ratio gauge and the readings were correct and what not. Recently the readings began playing up and after some research I found that roughly every 20,000 kms the gauge should be re calibrated, I did so about 2 days ago and already the readings are playing up.
Any advice on what i might be doing wrong?
Im thinking that i should re calibrate it again but thoroughly clean the sensor or something.
Need help: Innovate Air/Fuel Gauge readings
- D.A.M
- NitroDann
Re: Need help: Innovate Air/Fuel Gauge readings
You have an earth problem or an exhaust leak
- D.A.M
its reading from the extractors so the if it were a leak it'd be coming from there i assume hey? worth swapping over the gasket?
- NitroDann
Stock extractors crack at the collector often and the sensor is further down from there.
- D.A.M
Mine aftermarket CES Racing System ones, although they are aged, so you could be correct. ill check them out
- Steampunk
Is it the LC-1? If so then they are sensitive to significant vibration and heat and some instances fail very prematurely. Mount it on some thick foam/rubber (fireproof).
D.A.M wrote:So about a year ago I installed an Innovate Air/Fuel ratio gauge and the readings were correct and what not. Recently the readings began playing up and after some research I found that roughly every 20,000 kms the gauge should be re calibrated, I did so about 2 days ago and already the readings are playing up.
Hi Dam
did you solve this issue, i have an LC2 and it loses calibration and sends the MS into a weird rich setting. any help appreciated
Jaime
98 NB8A Grace Green
LS 66.17,QR Club 69.27, QRSpr 63.58 SOLD
01 NB8B Grace Green
LS 64.66,QRNat 1.31.94,QR Club 65.17 QRSpr 62.36
93 NA8 Clubman
01 NB8B Grace Green
93 NA8 Clubman
- Dan
Possibly a ground (or power) problem as Dann suggested earlier.
But saying that I had a similar problem with mine on my Evo and after verifying power and ground were good I asked my tuner about it because it still wasn't holding calibration and he told me to connect to my PC via a serial>usb cable and open LM Programmer to explicitly set the fuel setting I wanted which solved the issue permanently.
