My remote key has stopped working (NC2). The battery is OK.
Jitag
Postby Jitag » Thu Jul 23, 2015 6:35 pm
I'm looking for suggestions re troubleshooting this. My remote key has gradually lost power, with me having to get closer and closer to the driver door to get it to work. I changed the battery in the key, but it has made no difference. The key still works in the ignition, etc, but it is a pain in the proverbial to have to manually lock and unlock the doors and boot. I would love any suggestions; e.g. resetting the key somehow? Failing that, does anyone know how much a replacement key would be, and perhaps where one could be obtained in Melbourne, other than a Mazda dealer, as I know they will charge the earth. :cry: :NC:
JBT
Re: My remote key has stopped working (NC2). The battery is
Postby JBT » Thu Jul 23, 2015 8:16 pm
When you press a function button on the remote (lock, unlock etc.), does the red light come on brightly?
de Bounce
Postby de Bounce » Fri Jul 24, 2015 9:20 pm
One of my key fob did that also.
One fob kept working and I interchanged the various bits when the new battery didn't fix the problem.
I needed to reprogram the fobs as per the instructions posted HERE
Motorkhana Video
Jitag
Postby Jitag » Sat Jul 25, 2015 2:52 pm
Thanks everyone. I've tried the suggested procedure, but it didn't achieve anything. I waited the 40 seconds and tried it again twice; all to no avail. I will probably ring my usual service centre, and see what they suggest, and if that fails, I may have to ring the dealer.
Thanks again,
Jitag
pie5
Postby pie5 » Sat Jul 25, 2015 5:49 pm
This happened to me also.
Bought another fob from eBay ex the USA.
Slightly different but way cheaper than the Mazda AU Price.
2019 Racing Orange 30AE #783
2006 Stormy Blue NC 2.4 GWR Header & Exhaust, Progress Springs, Koni Shocks, Whiteline Sways, Recaros.
chrisb
Postby chrisb » Thu Mar 24, 2016 2:53 pm
How did you program the transponder part for the ignition? Not the keyless entry part.
pie5
Postby pie5 » Fri Mar 25, 2016 7:55 am
chrisb wrote:How did you program the transponder part for the ignition? Not the keyless entry part.
The chip in the key usually doesn't need to be reprogrammed. FYI, The chip is located inside the flip part.
If you remove the mazda logo there is screw underneath which allows you to unscrew the assembly to access it.
I had both keys and just needed to replace the keyless entry part.
chrisb
Postby chrisb » Fri Mar 25, 2016 12:11 pm
Yeah, but I was after a spare key not just a replacement
Steampunk
Postby Steampunk » Tue Mar 29, 2016 9:22 am
Tried disassembling it to check (and clean) the connectors?
