NA issue: pop-ups like to do their own thing...
CombatCarl
Postby CombatCarl » Wed Jul 22, 2015 8:02 pm
So I've lived with this issue for a while now by just hitting the pop-up button under the hazards when I want to use my lights, but if I just turn my headlights on without using that button, they will occasionally spaz out on me - closing themselves and turning off etc. ... not even at the same time! (sometimes it'll wink) - kinda dangerous.
I assume it is an electrical/contact problem within the indicator stalk but I just wanted to see if anyone else has experienced this or can recommend where to look?
HandyAndy
Re: NA issue: pop-ups like to do their own thing...
Postby HandyAndy » Thu Jul 23, 2015 11:46 am
I currently have a similar issue. Turning on the headlights will make the lights pop up but after a while, the lights will hide away again on their own (the lights are still on thought). I'm 90% sure it's a problem with the relay but I haven't been bothered to fix it because I just press the pop up light button under the hazard lights as you do and it gives me no troubles.
