ECU Equivalents
Posted: Wed May 27, 2015 10:48 pm
by Red_Bullet
Does anybody know if there are any Factory ecu with the same plugs as a 1994 MX5? Maybe from mazda 323, ford laser or........
I'm looking for one to gut for a MegaSquirt project.
Re: ECU Equivalents
Posted: Thu May 28, 2015 10:49 am
by 93_Clubman
1989-1993 NA6 had the same ECU plug & case (with a numbered different sticker) as the 1993-1995 NA8 ECU. Also, 323/Astina, Ford Laser, & probably Ford Meteor of similar vintage to NA6 & NA8 used the ECU plug & case (with different numbered stickers). Some Kia ECUs in some markets may also be similar enough.
ADM NA8 ECU plug colours I've seen have been yellow (1993-1994) & dark grey (1995). However, JDM & USDM NA8 ECU plug colours seem to vary from ADM, ie some 1993-1994 have been dark grey, & some have been yellow. NA8 ECU plug is also used by other manufacturers, but ECU cases may be different.
Re: ECU Equivalents
Posted: Thu May 28, 2015 2:07 pm
by madjak
I have the ECU female plugs if you need them. They can connect to the factory 1989-1997 harness. I bought these from Adaptronic.
