Cutting NB8A front bumper to fit foglight kit
vscalais
Postby vscalais » Wed May 27, 2015 8:28 pm
I have a 1999 NB8A and want to fit the genuine Mazda fog light kit. Does anyone have a template for cutting the front bumper please?
Cheers, David
Ask for forgiveness, not permission
smy0003
Re: Cutting NB8A front bumper to fit foglight kit
Postby smy0003 » Wed May 27, 2015 9:09 pm
[b]Then: Sunlight Silver NB8B
Now: Chaste White NA8
vscalais
Postby vscalais » Wed May 27, 2015 10:09 pm
Thanks smy0003 much appreciated.
vscalais
Postby vscalais » Wed May 27, 2015 10:10 pm
Does anyone have their early NB8A bumper off the car? If so could they please post a pic of the very small centre punch marks in the mold.
Apparently they show up on the bumper cover as LITTLE TINY bumps. They are spaced about 1/4" apart in an oval shape. At one apex of the oval (can't remember if it's the inside or outside edge) there are three very fine crosses that mark the location of the holes for the pins on the bezel.
Please email pics to dgolding01@optusnet.com.au
Cheers, David
Postby Mr Morlock » Sun May 31, 2015 1:54 am
Not sure why you would really want to do it. Fog lamps are pretty useless unless people really are in really foggy areas. I cannot remember when I last used my units and it's illegal ,though probably not enforced, to use except in inclement conditions. ps marks on the back of mouldings are usually where the sprues are cut off or date codings.
droo
Postby droo » Thu Jun 04, 2015 12:36 am
...i dunno, you of all people.. Maybe he wants to install them the way mazda engineers intended them to go..
Nevyn72
Postby Nevyn72 » Thu Jun 04, 2015 4:38 am
droo wrote:...i dunno, you of all people.. Maybe he wants to install them the way mazda engineers intended them to go..
Well then the answer's simple (in Morlock's world).... Take it to a dealership and have them do it! :roll:
bear2230
Postby bear2230 » Thu Jun 04, 2015 11:19 pm
Hey Dave I have some factory NB8B yellow fog lights if you need a set $100.00
Funnily enough I also have a really good NB8B bumper with a small bump as well for $200.00
vscalais
Postby vscalais » Fri Jun 05, 2015 12:11 am
I wish this was a straight bumper swap. Unfortunately it won't fit my NB8A without a lot of work.
Damn !!!!!!!
Postby Okibi » Fri Jun 05, 2015 1:38 am
Inside of early NB bumper
vscalais
Postby vscalais » Fri Jun 05, 2015 10:51 am
Well...at least this is my understanding anyway!
I know that I would have to upgrade my lights and wiring, and I believe that there are changes in the way the air flow is directed to the radiator.
Happy to be corrected of course.
vscalais wrote:I wish this was a straight bumper swap. Unfortunately it won't fit my NB8A without a lot of work.
Damn !!!!!!!
Postby hks_kansei » Fri Jun 05, 2015 5:01 pm
To my knowledge the only change needed is to also use the NB8B headlights (and make the minor wiring changes for them)
Radiator airflow won't be changed, the undertray may not line up perfectly, but it's flexible plastic anyway so can be easily pulled and pushed where it needs to be (just hold it in place with black cable ties, they seem to hold better than the factory scrivets anyway)
I have seen the change done without changing headlights (so purely just a bumper swap)
it physically fits, but the headlight shape is just slightly different, so leaves a couple of gaps between the light and the bumper.
vscalais
Postby vscalais » Fri Jun 05, 2015 5:17 pm
Thanks hks_kansei
Very tempting :lol: :lol:
Postby hks_kansei » Fri Jun 05, 2015 5:26 pm
You'd need to check with someone who's done it (timk, Lightyear, Boyracer, probably a few others)
But it's fairly easy from what I remember reading
vscalais
Postby vscalais » Fri Jun 05, 2015 6:28 pm
Agreed. Will check with Lou
