Need halp with ecu selection NB8B into NA6
Zabinskii
Postby Zabinskii » Wed May 20, 2015 7:40 pm
so im putting an nb8b bpve /z3 whatever you want to call it into my na6 and i wanna know, What ecu is best,
ill be doing a few things to the motor when its out, like Cams, shave the head, itbs, valve springs, maybe e85 (just for the sake of being able to run it when 98 goes up to 160 per l as it does every so often)
and im wandering what ecu is a good choice and where the best place to get the ecu is. Cheers!
ive been looking at the adaptronic but 1500$ is a bit more than i wanna spend at the moment. :)
Re: Need halp with ecu selection NB8B into NA6
Postby Magpie » Wed May 20, 2015 7:49 pm
How do you want to tune ? If professional then discuss with your choice of tuner, if DIY then select an ECU that is DIY compatible.
Postby NitroDann » Wed May 20, 2015 8:33 pm
10/10 answer.
