Nb boot release help needed. Calling nb8b owners
Posted: Fri May 15, 2015 11:15 am
by mx589
Hey guys boot release has never worked in my nb8b.
Now behind the carpet in the boot were the latch is there is this white plug.
Can someone else with a nb 2001 onwards tell me if there is a relay plugged into their white plug at this spot in the boot?
Any help will be appreciated
have googled for info but US forums are no good as theirs is wired differently than ours.
Re: Nb boot release help needed. Calling nb8b owners
Posted: Fri May 15, 2015 11:36 am
by pezchops
yes there is a small black relay.
the following lettering is on the front face
B110
DC 12V
N.0
IMASAN
2A12
Posted: Fri May 15, 2015 12:13 pm
by 93_Clubman
PC: believe you mean: Imasen LA12
MX589: plug for rear window demister relay is also located there, which variously uses the Imasen LA10 or Imasen LA12 relay.
Posted: Fri May 15, 2015 12:16 pm
by mx589
So does that relay do rear demister or boot release ?
I put multimeter on it and got 12v on one of the wires I think it was and when I pressed boot release on remote 2 of the wires spiked up to around 2.5v
Stuffed if I know we're il get that relay from. Looks difrent than any other relay I've seen on the car.
Any of you guys got a picture of it ?
Thanks for the info
Posted: Fri May 15, 2015 12:28 pm
by mx589
Just googled images
b110 does look like the right relay.
Posted: Fri May 15, 2015 12:38 pm
by pezchops
i imagine it must be available from wreckers ...any mazda from that era ,with a boot release probably uses the same relay
Posted: Fri May 15, 2015 12:51 pm
by 93_Clubman
Do you have more than one plug with or without a relay in it in the boot relaease area? If not, then perhaps it does both. Try Japanese car wreckers or ebay.
Posted: Fri May 15, 2015 1:00 pm
by mx589
Il have a look around
Thanks for the info guys
Posted: Sat May 16, 2015 3:07 pm
by mx589
Any of you guys have the factory mazda australia wiring books for the nb8b?
All the stuff i find on the net is for us models and is wired different than ours
Posted: Sun May 17, 2015 12:59 am
by Okibi
No sorry.
This post is for the NC but seems a similar set-up
Posted: Sun May 17, 2015 1:08 am
by mx589
yeh i had a read through that one already
thanks okibi
