Write-up: Stock replacement fuel pumps
Posted: Sun May 10, 2015 10:26 pm
The title should read universal fitment fuel pumps, because that is essentially what they are, unless you spend 2 arms and a leg getting a genuine one.
I write this because I found precious little information on the topic, so here I go sharing my information so that others may learn.
Firstly, you really need to be super careful working with anything related to the fuel system. Please read your workshop manual carefully before attempting and wear non-synthetic clothing and have a fire extinguisher next to you.
Also, my car is a JDM NA6, so unsure how applicable this is to other makes, but my fuel pump assembly looks like this with the conical connector to the fuel pump rather than a small length of fuel hose:
There are several pumps available off the shelf from the likes of Repco, Supercheap etc. The ones I have tried are the BOSCH and DENSO ones, but I was also told of a Fuelmiser one, but unsure about it.
The first one I got was the BOSCH pump because of its cheaper (than DENSO) price I couldn't go past it. When I was installing it I realised two things, first the kit does not contain a replacement o-ring. What you get is:
-fuel pump
-two different size filters (and lock washer)
-small section of rubber hose and two hose clamps (which you won't use anyway, at least on an NA)
-new wire clip with two bullet crimp connectors
When going to fit it the second thing I realised is that the filter was facing the wrong way which meant that it wouldn't fit into the tank.
After doing some more research I found that the DENSO pump came with the o-ring, and new grommet beneath the o-ring, but also that it might accommodate a filter which points the same direction as the stock one. However, the wire clip does not have the bullet crimp connectors, instead just had two exposed wires.
Side bar on electrical connections: Bullet connectors are okay in the fuel tank. Do not use heat shrink as it will melt in the fuel. Fuel resistant bullet connectors are the way to go. Otherwise, you could go about offsetting the wire connections to be extra safe. Also, on an installation note be extra careful to make sure that the wires do not impede the travel of the fuel float otherwise your gauge will show full when you run out of petrol.
In fitting the DENSO pump i realised that I was mislead about the filter direction (it's so difficult when there is next to no photographs of the products on the internet). So at this point I realised that I needed to re-use the stock in tank filter after a bit of clean.
Also, I also was tearing my hair out trying to remove the tiny screw which holds the fuel pump in, as it was bonded to its hole with some kind of inhuman strength. So it was replaced with a hex head bolt I had lying around. So just so long as you're aware you might have to fight it.
So cliff notes:
If you are attempting this job first make sure you have the following:
-BOSCH fuel pump (due to the superior connector and cheaper price)
-O-ring (B61P-13-ZE5) (this is like $20 on Amayama, so maybe try find a non-OEM one??)
-new in tank fuel filter (B61P-13-ZE1)
Hope that this has helped
-fuel pump
So cliff notes:
