mx5 OBD-II Ports
fcruz3r
mx5 OBD-II Ports
Postby fcruz3r » Mon Feb 23, 2015 8:15 pm
I recently brought some wireless obd2 diagnostic adapters and have sold a few on ebay.
Have had a couple of queries if they would work on an mx-5, but I don't know which model or year Mx5's came equipped with an obd-2 port.
Also read somewhere that the obd-ii ports on mx5's were mazda specific so you couldn't just plug a generic scanner because the port sizes were different...can someone please enlighten me on this.
Thanks in advance :beer:
Suspense
Re: mx5 OBD-II Ports
Postby Suspense » Mon Feb 23, 2015 8:32 pm
They started putting them on the NB8C, first built September 2002. They're a standard OBDII plug.
Caffeine
Postby Caffeine » Tue Feb 24, 2015 6:45 am
Suspense wrote:They started putting them on the NB8C, first built September 2002. They're a standard OBDII plug.
They actually appeared on mid 2002 NB8Bs, along with the low fuel light and the boot lights coming on automatically when you open the boot. My car missed out by about 3 months :(
bootz
Postby bootz » Tue Feb 24, 2015 2:21 pm
I can confirm Mid 2002
fcruz3r
Postby fcruz3r » Tue Feb 24, 2015 5:50 pm
cool...thanks guys.
so is the obd2 port in the cabin of the vehicle or in the engine bay?
also, anyone here in Perth with a mid-2002 upwards NB free to meet up and willing to let me test this adapter on their car? just need to see what sensors & gauges will work on torque-pro and dash command. If you have a turbo nb even better...that way I can see if it will read boost pressure as well.
Postby bruce » Tue Feb 24, 2015 7:21 pm
A turbod car will use a difft computer, thus deleting the OBD.
Caffeine
Postby Caffeine » Tue Feb 24, 2015 7:38 pm
fcruz3r wrote:cool...thanks guys.
It's in the fuse box underneath the foglight switches. Earlier NB8Bs have an OBDII connector shaped hole there.
Anyone with an SE should have OBDII.
Roadrunner
coyotes after you
Postby Roadrunner » Tue Feb 24, 2015 9:36 pm
SE will display:
Speedo
Tacho
MAF
Load
Coolant
IAT1 (at the filter)
IAT2 (at the throttle body)
Timing advance
Throttle position sensor %
Voltage
O2 sensor voltage 0-1.0v (not AFR)
Fuel trim
Things it won't show which most people want:
AFR
Oil pressure
Oil temp
Boost pressure
Any fast moving gauges are too laggy for real world use (rpm for example is almost a full second delayed)
Think that's everything.
MeepMeep
fcruz3r
Postby fcruz3r » Tue Feb 24, 2015 11:46 pm
Thanks heaps, much appreciated.
Havent found any noticable lag on the rpm gauge on my evo, but it is kinda hard to simultanously see both the ipad display and the rpm meter on my dash...did find that the more readings u display the laggier the reponse, guess thats just data transfer via the wifi connection
Roadrunner
coyotes after you
Postby Roadrunner » Wed Feb 25, 2015 10:04 am
My understanding is while the amount of info displayed will slow it down, the lag side of things is to do with the OBD port itself, or the specification of OBD used at the time.
Older cars are much slower than newer cars.
Iv seen new cars have zero lag what so ever with the same unit I'm using
MeepMeep
Mr Sexy
Postby Mr Sexy » Tue Apr 07, 2015 8:21 pm
I know this is an old thread but im in perth and own an se, if your still havnt found any one your more than welcome to give it a shot.
