NA6 with 440d wanting to run toyota cops
Posted: Fri Feb 20, 2015 2:47 pm
hey guys,
As the thread title says i have a 440d that im about to install and i have had it running with the internal MAP sensor (it runs with the VAF selected but when i put my foot on the gas peddle the rev's die and will stall.)
Im wanting to put some toyota cops i have here on the car. whats needed to make the swap?? i heard that if you do the swap you can loose you tacho. is this correct??
Mat
Mat
