Wideband 1" Spacer/Bung
Posted: Fri Feb 13, 2015 4:37 pm
by Dweezle
Hey all,
Installing my new MTX-L after my last one seemed to die.
Yeah fun.. NOT.
Anyways, my extractors bung for the O2 is at most 1/2" high.
Innovate recommend using a 1" bung and they provide it.
Would it be worth getting this installed in my Extractors or is there a easy way to just space it out that further 1/2 inch??
Re: Wideband 1" Spacer/Bung
Posted: Fri Feb 13, 2015 5:26 pm
by hks_kansei
How much thread is on the wideband?
over an inch?
if so you could probably just put a half inch wide nut on it first, then screw it into the bung.
(note, may not work if it's a tapered thread)
Posted: Fri Feb 13, 2015 5:33 pm
by Dweezle
Not a bad idea.
I will measure the thread and see if that will work.
Thanks!!
Posted: Fri Feb 13, 2015 5:44 pm
by NitroDann
There isnt that much.
Just make a large washer out of alloy or copper. Drill a 19mm hole for the sensor and make the washer large, doesnt matter what shape it is. Just make it a big heatsink.
Posted: Fri Feb 13, 2015 5:47 pm
by NitroDann
First pic on google
Posted: Mon Feb 16, 2015 11:50 am
by Dweezle
Thanks Dann.
The stock bung on the xforce headers is like 1/4".
As the thread count is quite low on the wideband sensor do you think I could just have the 1" bung cut down to say 3/4" and have that welded on the xforce bung to make it 1" long??
Posted: Thu Feb 26, 2015 7:03 pm
by Dweezle
All Sorted.
Suli helped me out on a wet Saturday Morning.
Thanks Mate
The sensor is now almost flush with the piping.
Much happier.
Posted: Thu Feb 26, 2015 7:50 pm
by Lokiel
NitroDann wrote:First pic on google
... that guy kind of missed the point on the heatsink, needs to be spun 90* for it to be more effective (ie. allow air travelling under the car to cool the fins optimally)
