learning what not to do.....Megasquirt 3
Posted: Wed Nov 05, 2014 9:32 pm
Hi Everybody,
I have an NB8A with a MS3 and ITB.
Was always running a startup tune since I got it a month ago, and my "refining" the tune/dashboard/firmware (update to 1.3.2a) has caused boiling and now no spark. Would the lack of spark be from changing "Tools" settings?
I did play with a bunch of things, so can't really relay clearly the sequence. I did revert to firmware 1.2.4, and the original tune, but I may have damaged the tune too.
If I can get it running ok for this Sunday's driving school, that would be great as a first base, then proper settings/tuning for smoother running and idle bypass valve next.
Would appreciate any assistance available, thanks.
Further to my previous note, I checked all fuses, all good.
Then I connected the original(?) ECU and it runs, sluggish as it did with that ECU when I tried it weeks ago. The Tacho works again now too!
