Starter relay in an NA8?
Postby bruce » Thu Oct 30, 2014 4:29 pm
Silly question, but what is it described as (Ignition relay)?
And where is it located?
Ta
Bruce
Re: Starter relay in an NA8?
Postby 93_Clubman » Fri Oct 31, 2014 10:39 am
Neither Rod's Miata 1.8 Enthusiast's Shop Manual or the Haynes Repair Manual index specifically list 'starter relay' or 'ignition relay'. But sounds like what's being referred to is either the NA6/8 'Fuel Inj' (or NB8 EGI Main) relay in the engine bay fuse box; or possibly the 'ignition control module' on the NA8 coilpack assembly; or even the 'starter interlock switch' on the left side of the clutch pedal support, not to be confused with the centrally mounted clutch switch.
Postby bruce » Fri Oct 31, 2014 12:21 pm
That's what I found too. There's no specified relay.
Thanks for the info Clubman.
