no high beams, sort of :-(
mmx005
Postby mmx005 » Fri Oct 10, 2014 12:02 am
Hi guys need a little help.
Went for a drive tonight in my 98 NB8A and when I put my high beams on, I lost my low beam lighting and everything thing went dark i.e. no hi or lo beam, just parkers and the blue hi beam light on the dash. HOWEVER the pass function works properly which tells me my globes and fuses are ok, i can also hear the relay click when i use pass (lights come on too) but no click or lights when using normal hi beam.
is there a separate relay for normal hi beam (ie when you aren't using pass? ??? Should i be looking for /at the previously mentioned relay or the switch at the end of the stalk or am i going in the wrong direction? ?????
I HAVE NO OTHER PROBLEMS and haven't done anything electrical in the car for quite a while.
Thank you in advance,
Ben
Caffeine
Re: no high beams, sort of :-(
Postby Caffeine » Fri Oct 10, 2014 8:01 am
The contacts in the combination switch (which controls the lighting functions) get dirty over time, and eventually will stop conducting. You can either take the switch out and clean it, or buy a replacement switch (that's what I did)
Caffeine
Postby Caffeine » Fri Oct 10, 2014 8:04 am
mmx005
Postby mmx005 » Fri Oct 10, 2014 10:14 am
Ok, does that mean removal of the steering wheel and air bag? ??
Caffeine
Postby Caffeine » Fri Oct 10, 2014 10:44 am
mmx005 wrote:Ok, does that mean removal of the steering wheel and air bag? ??
Yes it does, but it's quite straightforward.
myredmx5
Postby myredmx5 » Fri Oct 10, 2014 12:18 pm
I have a spare combination switch.
PM sent.
mmx005
Postby mmx005 » Sun Oct 12, 2014 1:31 pm
All sorted, thanks guys
