NA6 Radio Turned Off After Hitting Pothole
fknjexx
Postby fknjexx » Mon Sep 22, 2014 9:50 pm
Hey MX5CarTalk,
Whilst driving around the nasho, i hit a pothole and all of a sudden my radio completely turned off and wont turn on again. I disconnected it and reconnected all the wires in case there was a cut but it didn't solve it. Anyone know what could be the problem?
Thanks,
Justin
Re: NA6 Radio Turned Off After Hitting Pothole
Postby KevGoat » Mon Sep 22, 2014 10:15 pm
Did you check for power at the plug before reconnecting? Possibly a broken fuse, maybe a loose earth connection.
fknjexx
Postby fknjexx » Mon Sep 29, 2014 7:56 pm
KevGoat wrote:Did you check for power at the plug before reconnecting? Possibly a broken fuse, maybe a loose earth connection.
Hey, i didn't have a multimeter or anything so i wasn't too sure if power was going through, however i did connect another radio and that was functioning by ejecting a cd but there was still no lights for it to function properly, where can i check for the fuse? i also checked the ground and it's still tight.
Postby KevGoat » Mon Sep 29, 2014 8:15 pm
The fuse box is under the dash above accelerator pedal. Bit of a pain to get to. But if powered another unit, doesn't appear to be a fuse.
There would be two powered cables to the unit/plug. One would have permanent power (holds memory, clock etc), the other would only have power when accessories are keyed on via ignition.
Not too well at moment, so not thinking too clearly on what else to check ...
Caffeine
Postby Caffeine » Tue Sep 30, 2014 9:00 am
Most head units will allow you to eject CDs under standby power, but need auxiliary power to turn on. Sounds like you have standby power but not auxiliary power.
kalt
Postby kalt » Tue Sep 30, 2014 2:06 pm
What were you listening to when the radio broke?
Owning a fast car is easier than driving a car, fast.
For sale
NB8 Factory Airbox
fknjexx
Postby fknjexx » Sun Oct 05, 2014 11:01 pm
Problem solved! it was just the fuse, thanks guys :)
