Alarm Control Box Location
Posted: Mon Aug 25, 2014 6:48 pm
by Shadgrind
Trying to locate my control box for my alarm, so far have looked up behind dash, head on floor legs over seats! I drilled out the panel for the ECU, not there, took all the trim out the boot, not there. Looked under centre console, guess what? Run out of ideas. Oh, also looked under bonnet, traced wire back from siren 'till it vanished into loom.
Re: Alarm Control Box Location
Posted: Mon Aug 25, 2014 7:16 pm
by bruce
Follow the other end (where you touch the key).
Does it work? If not, maybe someone has ripped out the Box.
Posted: Mon Aug 25, 2014 7:55 pm
by SuperMazdaKart
Under the audio headunit?
Posted: Mon Aug 25, 2014 9:28 pm
by KevGoat
Had similar problem when first sorting wiring in my NB. Finally found it tucked in to a small gap to the left behind the instrument panel.
Sent from my GT-P1000T using Tapatalk 2
Posted: Tue Aug 26, 2014 4:39 am
by Shadgrind
bruce wrote:Follow the other end (where you touch the key).
Alarm works with remote, got a new remote to program , no touch key though. Tried tracing back the wire from LED it disappears into the loom!
Posted: Tue Aug 26, 2014 4:42 am
by Shadgrind
KevGoat wrote:Had similar problem when first sorting wiring in my NB. Finally found it tucked in to a small gap to the left behind the instrument panel.
to the left? Do you mean nearside? Have to be sure, how did you get at it? Have had instrument panel out and didn't see it, could have missed it though, maybeee[FLUSHED FACE]
Posted: Tue Aug 26, 2014 10:38 am
by KevGoat
I can only get to the wiring from mine by removing the instrument panel. I don't have the flexibility to distort myself to the angles required to see or reach that far up from below my dash, but it would be possible with the seat removed
Only found the module by chance. It's tucked in behind the dash metal through a small hole in the dash and because it's black and all the wiring is black, it looked like part of the dash. Had to chase along a lot of wires before I found the one that I could follow all the way to the module.
It's been over a year since I had it all apart so I can't recall the exact position or how it was positioned. It was towards the passenger side and below the instrument panel and above the steering column.
