Amp Behing Passenger Seat
Damon Clubman
Postby Damon Clubman » Sun Aug 17, 2014 11:22 pm
All:
Just a quick one.
I want to fit a small amp behind the passenger seat in my NA Clubman.
Am I OK to use 10mm tech screws directly into the rear wall/bulkhead skin or is the fuel tank there?
There would be a couple of screws about 200mm up from the floor about 250mm apart from centre of the wall and about 300mm higher up with the same spacing.
Non of the holes really above the arm rest height on the centre console.
You help would be great.
Thanks
Damon
Re: Amp Behing Passenger Seat
Postby Regie » Mon Aug 18, 2014 8:31 am
When I had an amp in my nb. I used Velcro to stick it there
Nevyn72
Postby Nevyn72 » Mon Aug 18, 2014 9:58 am
You'd want to be careful, the fuel tank is behind that bulkhead! :shock:
bear2230
Postby bear2230 » Mon Aug 18, 2014 5:44 pm
Regie wrote:When I had an amp in my nb. I used Velcro to stick it there
:lol: :lol: :lol: Qantas Engineer says use Velcro........Use Velcro.
Damon Clubman
Postby Damon Clubman » Mon Aug 18, 2014 5:49 pm
Velcro it is!
Ask first and then drill/screw later if Ok'd :D
Postby Regie » Mon Aug 18, 2014 7:45 pm
even found a pic :D
and1
Postby and1 » Mon Aug 18, 2014 8:08 pm
On my SE there are a couple of welded nuts on that rear bulkhead. I put bolts through them to hold a piece of mdf that my amp was attached to.
2005 Velocity Red MX-5 SE
Garage thread
Postby Jeo » Mon Aug 18, 2014 8:20 pm
I used velcro in the same place.
