Hi,
I left the lights on, flattened the battery and had to jump start the na6. Battery is fine now and all electrics work as before, except the radio.
The parrot Bluetooth system and speakers still work fine, the radio power light is on. However, the radio unit won't turn on. I have played around, but not sure what's wrong.
Any ideas? How and what should I check?
Itm
Radio stopped working after jump start
- Learner Driver
Re: Radio stopped working after jump start
Do you have the code for the radio?
- Learner Driver
It's an after market VDO CD radio player installed by the previous owner.
Check on the web to see if the radio needs a code.
