any help would be greatly apreciated
bartmanftw wrote:If you have an Australian delivered car then you're going to have to make your own wiring loom up to switch them on. I ran a wire from the fog light switch in the cabin through the firewall to the relay that came with the fog lights. I powered the fog lights through the fuse box using the spare fuse holder so that it looked oem. The 12V source I used to power the switch was only active when the parking lights were on so the fog lights would only turn on when the parking lights were on. Here's a wiring diagram that might help:
bartmanftw wrote:If you're talking about the plugs behind the dash buttons I don't think they switch anything on as far as I'm aware.
