aftermarket headunit help
Tezza
Postby Tezza » Sat Jun 14, 2014 2:08 pm
Hi, ive replaced my oem headunit with a sony xplode one. Ive got the plug and play thing wired for it. However everytime i play cd or usb the antenna has to go up even though im not using the radio. Does anyone know how to cancel this option or the antenna going up. However i would still like to use my radio. Thanks.
Re: aftermarket headunit help
Postby KevGoat » Sat Jun 14, 2014 2:39 pm
I just wired in a switch fitted in to my dash that stops it extending every time. If I put the radio on I can still use the aerial.
Tezza
Postby Tezza » Sat Jun 14, 2014 2:44 pm
did you use the antenna power wire and wired that to the switch?
Postby KevGoat » Sat Jun 14, 2014 2:47 pm
Yeah basically just cut the wire and connected to each side of switch. I found a switch that sits flush and looks pretty much as if it was always there. I rarely listen to the radio but I wanted the option just in case ...
Tezza
Postby Tezza » Sat Jun 14, 2014 2:51 pm
so i use that one wire and split it into two for + and -?
Postby KevGoat » Sat Jun 14, 2014 2:52 pm
Yup ...
Tezza
Postby Tezza » Sat Jun 14, 2014 2:53 pm
ok thanks for your help.
Postby KevGoat » Sat Jun 14, 2014 2:54 pm
On my phone so not sure if attachment will work but tried to attach photo of my switch ...
ED_MX5
Postby ED_MX5 » Sat Jun 14, 2014 3:30 pm
Another option, use this as a chance to change to stubby antenna.
That way, no antenna going up and down all the time.
Yet another option if you have ability to blank off hole, aerpro supply stealth kits that can mount underneath dash or seats. Very small and plenty of pick up.
Two that may interest you are:
-AP170
-AP259
Just a few thoughts outside the box.
-PRAISE THE LOWERED-
Postby KevGoat » Sat Jun 14, 2014 4:04 pm
Those hidden aerials are good actually. I fitted one to my Father in law's car about a year or so ago and just plugged the old hole in the fender with a rubber grommet that fitted neatly.
Postby KevGoat » Sat Jun 14, 2014 6:30 pm
Ok, so just got back on my laptop & my attachment above failed :?
Here's the switch I added:
chrisearl88
Postby chrisearl88 » Sat Jun 14, 2014 6:48 pm
Are you sure you haven't wired it up to the remote amp turn on? Check the wiring diagram on the manual or get the multimeter out. On most aftermarket HU's there are two outputs. One for power aerial and one for amp turn on. On my Sony headunit, the amp power obviously shows voltage whenever the HU is on, but the aerial power lead on shows voltage when the radio function is selected. You might have inadvertently wired it to the wrong one, which will still work.
Postby KevGoat » Sat Jun 14, 2014 6:56 pm
Depends on the HU as well. My Pioneer HU powers the aerial as soon as the HU powers up, irrespective of what is playing. I've a feeling all Pioneers do this, but don't quote me. An old Philips unit I had years ago only powered the aerial when the radio was selected.
Tezza
Postby Tezza » Sat Jun 14, 2014 11:56 pm
yeah i think i wired it to the amp so which wire to i wire it to now?
Postby KevGoat » Sun Jun 15, 2014 1:16 am
It should say in the manual. If you don't have that, a circuit tester is the simplest way to tell which wire is active only when the radio is selected. Cheap tool from any auto parts or even Bunnings etc. A must have item if you are going to be doing wiring. Either that or a multi meter.
Just "Google" how to test a circuit...
Sent from my GT-P1000T using Tapatalk 2
