Hi,
I have installed a nb8a cluster in my nb8b.
expect the high beam light is always on, i have found the thread on cartalk regarding a similar issue but its is for nb8b cluster in nb8a.
Any help?
NB8A CLUSTER IN NB8B
- Vehicle: NB Roadster
WINTON PB - 1:57.4000
- KevGoat
Re: NB8A CLUSTER IN NB8B
narita wrote:I have installed a nb8a cluster in my nb8b.
However, having "Googled" and also found no answer, I'd take a wild guess and suggest that your problem is a reverse of the issue to the earthing problem of an NB8B cluster in to an NB8A mod .....
I had to add an earth wire to get my high beam lamp to work, maybe yours is constantly earthed somehow?
Thanks kev that seems to make sense.
As to why well i installed some rev limiter faces a while back and me being a disabled mechanic all the readouts are way off. Got tired of it and picked up an nb8a cluster!
swapped the circuit boards over.
everything is as mazda intended. Success!
This also allows me to keep my old ODO.
- KevGoat
Just a thought, but maybe place both clusters side by side and see if you can work out the variation in the circuitry to the high beam lamp that way. I couldn't find a clear enough image online of the NB8A cluster rear circuitry to check against the photo of the NB8B that I have on my laptop.
Good luck ...
Good luck ...
Hey kev read above post.
i swapped the circuit boards and now its fine!
- KevGoat
We must have posted at same time haha ...
Glad it worked out ;)
Sorry kev i do appreciate your help!
Maybe some others will find this idea usefull.
thought i doubt anyone else wants to backward modify.
