keyless pushbutton start help!!
Posted: Thu May 22, 2014 6:40 pm
Hey guys,
So I'm planning on installing some switches to run my car (99 nb8a). Two toggle switches for "Acc" and "On". A third momentary toggle for 'Start'.
I've figured out all the wires from the ignition barrel wiring, so that's no problem. I also know that I can drill out the steering lock mechanism so that's also no problem.
HOWEVER it wont start unless the key is in the ignition. Using ONLY the switches the car will start but it will die half a second later. Using the switches and just leaving the key in the ignition the car will run as normal. Even though the key isn't actually wired to anything
Is there a chip or something in the key that means it's necessary to be in the ignition? Is there anyway I can bypass the key being in there as that defeats the purpose?
Any help is appreciated.
Cheers in advance
Cheers in advance
