electric windows are not working
Ive checked fuses. under dash & engine bay. several times....unless ive missed one.
its unlikely the ignition barrel. when thats faulty. the wipers & wiper water dont work either. both those work.
switch?
any Idears where to start looking
if anyone knows which fuse....I'll check it again.
NA6 Electric windows stopped working.
- StanTheMan
Re: NA6 Electric windows stopped working.
Is the window motor working?
It could be the switch contacts. Do you have a multimeter?
- StanTheMan
I don't have a multimeter. Wouln't have a clue how to use one either.
neither window is working. So that kind of makes me think its either a fuse or a completely buggered switch.
the switch itself it is not possible to remove wiring without cutting the wire....so cleaning contacts....perhaps not possible?
- StanTheMan
So I can't clean the contacts.
But I guess I'll take the switch apart & clean internally?
- StanTheMan
Thank you to a very kind person who sent me the fuse diagram via PM
To that person.
Thank you so much. I missed that fuse a few times
Windows are working.
Thanks all.
one happy camper
To that person.
Thanks all.
one happy camper
By the way you can clean the contacts. Pop the switch apart. This is how you can rectify slow windows.
- StanTheMan
Ok cheers
- Vehicle: ND - 2
Hi.
If you take the switch apart do it with the switch in a bag to contain the contacts as they are rather small.
