Got home...just
Odd
Got home...just
Postby Odd » Sun May 04, 2014 9:17 pm
Went on my first Mazda club run
FANTASTIC!
However....the car didn't behave
1hr 40min trip from Brisbane to Eumundi...car didn't miss a beat
(2 hours each way to Springbrook and back Saturday....perfect!)
Arrive Eumundi early...quick coffee, then off to the check point
Allocated a team....away we go
10 mins into the run the car starts to miss fire under load
Make it to morning tea....seems maybe a bad lead
Off again....3 cylinders most of the way....but wasn't left behind!
Lunch at Pomona....and who was waiting for me....the RACQ ....just attending to someone else by chance!
He wrapped a plug lead in electrical tape and the car idles well....off to lunch
Take off to head home.....better, but not Good....10 minutes into the trip....seems to be only 2 cylinders working!!!
Stopped at 2 Supercheaps....don't stock mx5 leads....so headed home with motor misfiring badly...motor seems to idle on 4 cylinders but misfires once accelerator is applied
Off overseas tomorrow for a week
Will order new leads and spark plugs....but I think one of the coil packs has given in
Will post progress as information for others.....
Other comments of what problems could be
Cam sensor
O2 sensor
All other comments welcome!
Still a great day....!!! :D
And I'm amazed with the car.....NA8
any other sports car I've owned would never have made it home!
You can't demand respect....you have to earn it
NA8 for Fun, CX5 for carrying crap...;)
JBT
Re: Got home...just
Postby JBT » Sun May 04, 2014 9:32 pm
You'll probably find the new leads will fix it. :wink:
cookie
Re: Got home...just
Postby cookie » Sun May 04, 2014 10:48 pm
Sounds more like a faulty coil pack. Glad to know it's home to fix though.
taminga16
Re: Got home...just
Postby taminga16 » Sun May 04, 2014 11:02 pm
Start small Leads and plugs first. If it is still misfiring, borrow a coil pack.
davekmoore
Re: Got home...just
Postby davekmoore » Mon May 05, 2014 2:19 am
taminga16
Re: Got home...just
Postby taminga16 » Mon May 05, 2014 10:16 am
Well spotted Dave. I wont ask what you were doing up. :)
Odd
Re: Got home...just
Postby Odd » Mon May 05, 2014 10:46 am
Apparently the car is Early 1995
Compliance 5/1995
I'm looking to order a coil pack while I'm away
In March they were 4 pin.....April on they were 3 pin
Is there any where on line I can check with a vin number?
Unfortunately I can't check car till Friday night and I want to fix it Saturday
And part needs to be ordered in ;)
Thanks
Re: Got home...just
Postby manga_blue » Mon May 05, 2014 10:57 am
New coil packs are not cheap and you don't yet know whether or not yours is faulty. As Taminga said, borrow a coil pack first.
The only way to reliably check for 3 or 4 pin is to disconnect a plug from the bases of the coil pack.
Odd
Re: Got home...just
Postby Odd » Mon May 05, 2014 4:12 pm
Thanks for the advise re borrowing a coil pack....makes a lot of sense
Having done a bit of research....these cars are a bit more complicated than my old sprite
Problem maybe, leads, spark plugs, coil packs....or something else which has got the ECU sending wrong info?
That said....this being a 20 year old car(almost) I figure there is no harm in collecting a few spares....if it's not the coil pack now.....it maybe next time, so it's not necessarily wasted money...???
I'm not back in town till Friday night....and hope to get it fixed Saturday, so just trying to get the ducks lined up....
I haven't personally worked on cars for 30 years....but quite enjoying the research and learning....will line up a led and diode this week and check if there is an error code
All comments appreciated.... :)
Re: Got home...just
Postby bruce » Mon May 05, 2014 5:40 pm
Plug leads!
davekmoore
Re: Got home...just
Postby davekmoore » Mon May 05, 2014 7:21 pm
bruce wrote:Plug leads!
and you could have the ones in the link I mentioned waiting for you by Friday.
How good is your battery by the way?
Odd
Re: Got home...just
Postby Odd » Tue May 06, 2014 12:30 pm
Thanks…. :D
Battery is New….replaced for roadworthy
Is there an error code for coil pack failure??
Re: Got home...just
Postby manga_blue » Tue May 06, 2014 12:45 pm
Maybe it's time you learnt about Garage on the Big Forum. :D http://www.miata.net/garage/faultcodes.html
I've had Minis, MGs, Anglias, Jags and random other Morrises and Austins. I know where you're coming from with Sprite electrics - Lucas: Prince of Darkness :roll:
ECUs and sensors are a bit of a learning curve but it's all easier and much more dependable in the long run.
TTT
Re: Got home...just
Postby TTT » Tue May 06, 2014 12:47 pm
Odd wrote:1hr 40min trip from Brisbane to Eumundi...
Were you stuck in 2nd?
Odd
Re: Got home...just
Postby Odd » Tue May 06, 2014 1:09 pm
Thanks manga_blue
Tending to think I should find out what the problem is first….If I buy parts for all the guesses it to add up to some serious cash
if it means the car stays in the garage for a few more days….it's not the end of the world
TTT
Haha
Speed limit all the way….+10min stop to fill up…petrol/coffee
