Re: NC Cruise Control Fault ?
Posted: Sun Apr 13, 2014 10:46 am
by Mr Morlock
Guessing is not the go I am afraid- just do what almost everyone else does and go to an establishment that can check diagnose and repair the fault. If you have access to an OEM workshop manual ( refer recent thread) it might give some info.
Posted: Mon Apr 14, 2014 3:38 pm
by taminga16
Locate the fuses for the cruise control, disconnect the battery, remove the fuse/s (there may be more than one) re-connect the batery and then follow the requirements in your owners manual re; DSC, TCS, ABS etc . Drive the car for a day, you know on/off, start/stop etc. disconnect the battery, replace the fuses, re-connect the batery and then follow the requirements in your owners manual re; DSC, TCS, ABS etc again, test the Cruise control and if it is not functioning correctly consult an Auto electrician, as Mr M says an on-line diagnosis is a long call.
Good luck.
Greg.
P.S. There is a manual in here somewhere.
Posted: Mon Apr 14, 2014 6:27 pm
by taminga16
Aussie,
I had a few minutes today. Check here, http://www.mellens.net/mazda/Mazda-Miata-2006-2007/
Greg.
