NA6 interior lights faulty?
Posted: Wed Jan 22, 2014 2:19 pm
by lovelyqoo
Quite recently the interior dome lights of my NA6 has started working...abit strangely.
On off mode both lights are off. On door mode both lights are on, WITH AND WITHOUT the door being closed. On On position, they are OFF.
Needless to say it is abit annoying when I try and get into my car at night.
I did put new water into the water squirter bottle in the engine bay the afternoon before it stopped working, would I have shorted any wire?
Any help would be appreciated! Thanks
Re: NA6 interior lights faulty?
Posted: Wed Jan 22, 2014 3:26 pm
by hks_kansei
with them in the "door" position open a door and find the little black plastic nipple in the door frame. That's the switch that lets them know the door is open/closed.
Press the switch in and out to see if the lights go on and off. They should go off when the nipple is pressed in. (only have one door open at a time)
it's possible those switches are faulty and stuck on, leaving the lights on all the time. The contacts for those switches often get rusty.
It wouldn't explain them being off when the switch is set to always on though?
Posted: Sun Feb 02, 2014 9:08 pm
by mazdaz
Wait...what.....NA6 has interior lights...where?
Posted: Mon Feb 03, 2014 9:05 am
by sailaholic
Guessing import? Na8 has them near the Tombstone facing into the footwell
Posted: Mon Feb 03, 2014 9:25 am
by NitroDann
I thought all of them did. I just turn them off they dont light anything up.
Posted: Mon Feb 03, 2014 11:59 am
by hks_kansei
Mazda really didn't think the itnerior lights through on NA or NB.
NA has fine light output, as long as you wanted to look at your feet.
NB had a light in the windscreen header with great positioning...... that they decided to tint the lens dark so it's really dim.
Posted: Mon Feb 03, 2014 1:47 pm
by aka_juffa
Unable to add any advice on the original question not already given by earlier posters.
With regards to the light output and direction.
Get yourself down to your local Jaycar store, and pick up two of these ==>>
http://www.jaycar.com.au/productView.asp?ID=ZD0484After installing the new globes, rotate the light fittings 180 degrees so the light is facing up.
Not as good as an overhead light.....but 1000% better than the oginal setup.
I would post some picture, but I stole the globes out of the MX-5 and installed them in the Outback.
J
Posted: Fri Feb 07, 2014 4:06 pm
by JEM.81E
Mine does this sometimes, try placing the switch between the ON and DOOR positions.
Just have a fiddle around with the switch to get the sweet spot for them to turn on or it could be the globe inside not getting enough contact so try those as well.
Posted: Fri Feb 07, 2014 4:15 pm
by hks_kansei
JEM.81E wrote:Mine does this sometimes, try placing the switch between the ON and DOOR positions.
If that's the case you can likely fix it by bending the globe contacts out a little and giving them a light sand.
Or buy a can of electrical contact cleaner and blast the contacts for the globe, and the switch.
That stuff works wonders.
Posted: Sun Feb 09, 2014 7:40 am
by mazdaz
ok...where exactly are these light meant to be and how many? thanks
Posted: Sun Feb 09, 2014 9:26 am
by hks_kansei
mazdaz wrote:ok...where exactly are these light meant to be and how many? thanks
That guy seems to have modified his in some way for more light, but the position is the same.
There will be a second one on the driver's side in the same position.
Posted: Sat Feb 15, 2014 10:43 am
by mazdaz
Well there you go thankyou
Posted: Sun Mar 23, 2014 5:21 pm
by Gladiator
Mine have never worked. I bought a torch.
