2000 Nb head unit removal???
meanmx
Re: 2000 Nb head unit removal???
Postby meanmx » Sun Dec 08, 2013 8:41 pm
It's tough. I had to get at mine from behind.
2014 VW Mk7 Golf R
markwid
Postby markwid » Sun Dec 08, 2013 9:07 pm
Tried this?
meanmx
Postby meanmx » Sun Dec 08, 2013 11:02 pm
Man that guy in the vid made it look so easy. Ok, I used 3 nails each side to remove mine. What I did was remove enough trim to be able to get my hand around the back and then feel the clips on the side. If you can imagine it, I had my hand stretched behind the unit feeling the clips while putting the nails through the holes in the front making sure they sat properly. Others have gotten them out easy but mine didn't want to budge. Still incredibly painful but it came out. If you are still stuck tomorrow I can take a picture.
2014 VW Mk7 Golf R
Postby Lokiel » Sun Dec 08, 2013 11:11 pm
Download the "entertainment system.pdf" file on this link and start at Page 33 of 74: https://drive.google.com/folderview?id=0B3YbfB30DxW0bEdwS0xSNGVXMzA&usp=sharing
Basically there are two long thin plastic horizontal snap-in tabs on the side of the stereo unit.
Use a small screwdriver or credit card to pry them off.
Behind that you will see there are a few of holes.
The guide talks about a SST Removal tool - I just cut up a metal coathanger and made mine (similar to Figure 38).
Insert the U-shaped metal "tools" into those holes as far as they will go (no need to use force) and pull backwards and outwards simultaneously - this pushes in the retaining tabs and the unit "should" slide out - in practice it takes most guys a while to get it out. The stronger your "tool" and more "snug fitting" in the hole is, the easier it will be - my coathanger "tool" probably wasn't strong enough which is why it took me a while.
de Bounce
Postby de Bounce » Mon Dec 30, 2013 5:48 pm
You could read this thread
http://mx5cartalk.com/forum/viewtopic.php?f=78&t=28063
Titled "The Idiots guide to replacing a stereo in the NB8B"
Motorkhana Video
