Which vacuum line for Megasquirt DIYPNP
Posted: Sat Dec 07, 2013 7:47 pm
I'm running through the procedure for installing the Megasquirt DIYPNP and I can see that I need to attach a vacuum line. On the http://www.mx5unleashed.com/tech/megasquirt-pnp.html guide is says:
And provides a nice image:
http://www.mx5unleashed.com/1-pix-mx5/t ... G_9800.jpg
Attached is a pic from under my hood. Obviously I don't have the extra pipe, so should I 'T' off the line that is there (1), or can I hook directly to the plugged line (2)?
After that the vacuum line, I have another pipe added to the intake plenum but you can put a "T" on the vacuum line going to the cruise control, the other one goes to the carbon canister and there is a switch that switches on and off which would produce pulses in your signal.
