How to rebuild your alternator (54K unfriendly)
spikes
Postby spikes » Thu Nov 28, 2013 9:44 pm
Hey guys, thought I'd write this up. It all started with me just wanting to clean the two alloy case halves up, nek minute I'm ordering new bushes and bearings.
Okay lets start off, this is a NA8 alternator, its a Mitsubishi A2T80391.
I ordered the brushes off eBay, and bearings I got from a local bearing store.
The front bearing is a quite a common size, the 6303. Dimensions are 17mm I.D x 47mm O.D x 14mm height
The rear bearing is a 140419, 8mm I.D x 23mm O.D x 14mm height.
I didn't get any pics, but the easiest way to get your alternator pulley off is to wrap an old belt around it or grip it with mechanic gloves, and zap it the nut off with a rattle gun.
Then mark the outer casings so you can line it up again when you put it back together.
Remove these 4x 8mm bolts holding the two halves together
Give the mounting arms a tap with a hammer and the top half should come off. Be careful as the rotor can fall out, and damaging it.
Once the rotor and the top half is off, give the lower half a tap with the hammer and the stator should seperate from the lower casing. Be careful here as the stator is attached to the rectifier/regulator unit. You want to tap it just enough to seperate it from the casing but not too hard that you rip the wires from the rectifier unit.
Now you can go ahead and remove the rectifier and voltage regulator unit. Remove the three screws holding it in.
And then the 10mm at the back, if there's a cover on it, pop it off.
Now, remove the front bearing plate, and drift the bearing out
And drive the new bearing in.
New vs old
The rear bearing, use a 3-jaw puller to pull it off. I didn't manage to get any pics at this stage, was too involved and forgot.
This is the rear bearing
The rectifier/regulator unit
I followed these steps to test my rectifier/regulator, and all was in good working order.
Now onto the brushes, found these guys on eBay for $4.50 posted.
Pop the plastic cover off to expose the brushes
Using a soldering iron, melt the solder and the top of the plate holding the brushes will pop out.
Hey presto!
And solder the new ones in
Make sure these holes line up, because you will use that to hold the brushes down to insert the rotor. Also, I'd recommend giving the slip rings and rough once over with some fine sand paper, just roughing the surface up a little.
spikes
Re: How to rebuild your alternator (54K unfriendly)
I also cleaned up the cases, and sprayed them with high temp paint.
Now, put the stator/rectifier/regulator back in, screw it back up and find this hole at the back, if you don't have one, drill one. This is to insert a pin or needle to hold the brushes back.
And the reassemble in reverse order.
So there it is, it costed me $30 and about 2hrs of my time. Well worth it!
geofiz
Postby geofiz » Fri Nov 29, 2013 9:31 am
Awseome write up, thanks for sharing. :NETPOINTZ: :NETPOINTZ:
NB8A - mostly stock for now
Postby Okibi » Fri Nov 29, 2013 9:57 am
Great write up, a mate (ex mechanic) got given the run around trying to buy alternator bushes recently, glad you can just ebay them.
I've watched this video before, wasn't a bad way to get an idea how a typical alternator is fixed but your photos are 1 better!
bigmaxy
Postby bigmaxy » Fri Nov 29, 2013 10:19 am
Excellent post and I had a little LOL at the title. I don't even know if it is possible to get a 56k modem connection anymore in most pasts of the country.
Dehamsta
Postby Dehamsta » Fri Nov 29, 2013 1:23 pm
Great post! Will be very handy one day.
spikes
Postby spikes » Fri Nov 29, 2013 1:30 pm
bigmaxy wrote:Excellent post and I had a little LOL at the title. I don't even know if it is possible to get a 56k modem connection anymore in most pasts of the country.
Nowadays, it's more of a warning for lots a lots of pictures haha
mrpham
Postby mrpham » Fri Nov 29, 2013 4:43 pm
Awesome stuff mate! Wish you posted this before I did mine, would have helped a lot :)
Current Forum Specials!
maxgus
Vehicle: NB8A - Supercharged
Postby maxgus » Fri Nov 29, 2013 10:33 pm
Great write up thanks. I am going to tackle this very job soon and this will be a massive help.
Feather weight
spikes
Postby spikes » Sat Nov 30, 2013 1:40 am
mrpham wrote:Awesome stuff mate! Wish you posted this before I did mine, would have helped a lot :)
Your obsession with clean parts was my inspiration for wanting a clean new looking alternator in the first place! :)
Postby fastfreddygassit » Tue Dec 03, 2013 12:57 pm
Excellent write-up and some nice pics too!
:BROADY: :NETPOINTZ:
May I suggest we sticky this and possibly include it in the MX5 technical guide sub forum too?
Users browsing this forum: No registered users and 92 guests
