Airbag warning light
tescoking
Postby tescoking » Tue Oct 15, 2013 11:14 pm
Hi guys, I swear I searched the forum and I did find a topic about the airbag warning light on NB.
However, I really don't know how to fix the problem, do I HAVE TO take it to professional or can I do it myself?
It happen when I was drving through a rough surface the other night, and I thought restart the car could fix the problem and it didn't, please give me some help.
My 5
Re: Airbag warning light
Postby hks_kansei » Wed Oct 16, 2013 1:49 pm
Knowing the problem might make helping easier.
Is the light staying on?
Is it not coming on at all?
Is it blinking?
Postby KevGoat » Wed Oct 16, 2013 1:58 pm
The light will usually flash a code.
Sent from my GT-I9100T using Tapatalk [url='http://tapatalk.com/m?id=10']now Free[/url]
tescoking
Postby tescoking » Thu Oct 17, 2013 3:21 am
it keeps flashing 7 times
My 5
Postby KevGoat » Thu Oct 17, 2013 9:37 am
Try this : http://www.miata.net/garage/airbag_blink.html
Postby KevGoat » Thu Oct 17, 2013 9:39 am
There's a plug up behind the glove box. Check that's not loose.
tescoking
Postby tescoking » Thu Oct 17, 2013 6:59 pm
so it seems like it is the passager side airbag problem, is there any way to fix the problem?
My 5
Postby KevGoat » Thu Oct 17, 2013 9:12 pm
According to Miata.net later models also had a connector under the seat. Not sure if this is the same here but they discuss some problems with that connection causing this code.
tescoking
Postby tescoking » Thu Oct 17, 2013 10:43 pm
KevGoat wrote:According to Miata.net later models also had a connector under the seat. Not sure if this is the same here but they discuss some problems with that connection causing this code.
I believe there are no connector under passager side seat but driver side does have one and it is the seatbelt warning light
My 5
Postby KevGoat » Thu Oct 17, 2013 11:11 pm
That switch won't have any bearing.
Once you have checked the connections (make sure you push them in hard to ensure they are making contact) my next step would be to disconnect the battery for a few minutes to try to clear codes. Reconnect, start the car and see if the code persists.
tescoking
Postby tescoking » Fri Oct 18, 2013 1:11 am
KevGoat wrote:That switch won't have any bearing.
do you have a photo of the connection, i can't quiet find it
My 5
Postby hks_kansei » Fri Oct 18, 2013 12:58 pm
Also remember that if you're reading a US based site (like Miata net) when they reference "passenger side" it may be driver's side on our cars.
Postby KevGoat » Fri Oct 18, 2013 2:29 pm
Need to remove the glove box to see it. Looks like this:
Push it together tight to make sure the contacts are connecting properly. Could be that the recent bumps dislodged it slightly. Happened to mine and I had same code. I've since put zip ties along to hold it all in place better and even after several k's of pretty rough dirt road recently the problem hasn't re-occurred **touches wood**
If that doesn't solve it, the ECU often stores error codes, so quite often even after fixing a problem, the light will still flash. The codes require clearing by disconnecting the battery for a few minutes.
Good luck :wink:
Postby KevGoat » Fri Oct 18, 2013 2:32 pm
hks_kansei wrote:Also remember that if you're reading a US based site (like Miata net) when they reference "passenger side" it may be driver's side on our cars.
haha ... wish I'd remembered that when I was initially wiring the NA8 electric mirrors in to my NA6. Would have saved a lot of unnecessary frustration :mrgreen:
tescoking
Postby tescoking » Fri Oct 18, 2013 4:11 pm
thanks mate, i will try it now
My 5
