So I have had this issue for a while and have put it off but now my rego is due and I need to fix it... when I use my right indicator I get the fast clicking sound (like when a bulb is blown) but all are fine.... none of the right side indicator lights work, the arrow on the cluster doesn't light up, both the fuse and indicator stalk are fine as well, when I use my hazards only the left indicators and left cluster indicator arrow light work and im now at a bit of a loss.. I think it may be something wrong with the ground but Im no sparky and I don't want to tinking with the wiring if its not necessary.
Car is a 90 NA6
Indicator issue
Re: Indicator issue
checked the relay?
Re: Indicator issue
on mine,after checking everything else, it was this
http://www.miata.net/garage/turnsig.html
it took about 6 mins to fix.(had to wait 3 mins for soldering iron to heat up)
Mick
Mick
Re: Indicator issue
yeah tried that fix but didnt do anything... still does the same thing.... anyone in the newcastle are have a relay i could borrow just to see if that is the issue... before i go and buy one and to just cross that off the list of possible issues?
Re: Indicator issue
Email sent.
