Sandwhich plate help.
narita
Postby narita » Mon Sep 09, 2013 11:54 am
yesterday i installed a sandwhich plate with oil pressure and oil temp senders.
this is the type of plate Image
it all turns on and such but i am not receiving signals, oil temp shows dead cold and pressure is all the way UP.
now i was under the impression with npt threads you shouldnt tighten then more than half way down.
is it possible i am wrong and i need to screw the senders down more to immerse them in the oil?
thanks in advance.
WINTON PB - 1:57.4000
Re: Sandwhich plate help.
Postby NitroDann » Mon Sep 09, 2013 11:56 am
No pic.
narita
Postby narita » Mon Sep 09, 2013 12:03 pm
sorry!
this is my plate
sailaholic
Postby sailaholic » Mon Sep 09, 2013 12:04 pm
Pic works for me. Site you have your electrical stuff correct? If your senders aren't leaking, the shouldn't need further tightening.
narita
Postby narita » Mon Sep 09, 2013 12:07 pm
im pretty confidient that the wiring for the senders isnt to fault but if all else fails i will double check them.
noobee
Postby noobee » Mon Sep 09, 2013 12:11 pm
anodised,poor earth?
Mick
narita
Postby narita » Mon Sep 09, 2013 12:14 pm
i assume you mean earthing on the senders?
well i used loctite liquid sealant so that shouldnt cause an issue.
as for the electrical earth well that is fine.
sailaholic
Postby sailaholic » Mon Sep 09, 2013 12:22 pm
Wires backwards?
narita
Postby narita » Mon Sep 09, 2013 12:24 pm
wires cannot be backwards as one end has a plug.
sailaholic
Postby sailaholic » Mon Sep 09, 2013 12:55 pm
Short your sender write to earth rather then attach it to the sender if see if the readings are the same or opposite?
Postby manga_blue » Mon Sep 09, 2013 2:47 pm
Earthing looks a problem. You need good metal to metal contact between the plate and the engine and between the sender and the plate. Anodising and loctite won't help that. Test with a multimeter that you have good earth continuity from the engine to the sender body. You may need to rub off some anodising and replace loctite with copper-rich grease if it fails this earth test.
Also never ever use thread tape on sensor threads. That guarantees that they can't work.
narita
Postby narita » Sat Sep 14, 2013 12:39 pm
noobee wrote:anodised,poor earth?
Mick
ok so after some research im quite sure it must be the poor earth due to the sandwhich being anodized.
what would be the best way to ensure a solid earth?
