Low beam problem on NA6
popopocky
Postby popopocky » Sat Aug 17, 2013 10:25 pm
Hi All,
I just lost my left side low beam head light on the way home. High beams work perfectly on both side
I've checked all the related fuses, all look ok. Bulbs are fine too.
I've also checked the voltage on the connector and got 12V on both low beam and high beam wires.
Any suggestions?
Re: Low beam problem on NA6
Postby NitroDann » Sat Aug 17, 2013 10:32 pm
bulb.
Postby Regie » Sat Aug 17, 2013 10:34 pm
NitroDann wrote:bulb.
yep :BROADY:
popopocky
Postby popopocky » Sat Aug 17, 2013 10:50 pm
Thanks guys!
Just double checked with another set of bulb and its alive :oops: .
Postby 93_Clubman » Sun Aug 18, 2013 12:28 pm
Filament coating often deteriorates, without breaking, to the point it won't work. Both sides of mine did this within about a year of each other.
