Here is my grounding kit.
Okibi wrote:I wouldn't have one going across the ignition lead.
david_syd_au wrote:You should find a route for the wire which doesn't involve it passing near the HT leads.
Having 2 wires close together, with one of them carrying high voltage pulses, can result in current being generated in the other wire through inductance
Best keep them apart.
hks_kansei wrote:Ignoring my personal thoughts on grounding kits, it looks installed correctly.
As long as nothing is grounding to a positive wire/connector, and that the grounds are all to metal (ie: bare metal, not paint) it should be fine
tescoking wrote:Isn't it suppose to install to some certain spot?
