While the Adaptronic website still lists a generic long & short loom for the E420C, they also stock NA6/NA8 ('93-'95) ECU header connectors & the custom made PCB for same if you ask. So you can make a PnP loom from a generic one or convert an existing loom.
Imagine this also applies to the components for the NB8A & NB8B.
As usual Andy was very helpful & the parts were reasonably priced. Andy also provided a link to NA wiring schematic & base map:
http://adaptronic.com.au/forum/index.ph ... ttach=4072
http://adaptronic.com.au/forum/index.ph ... ttach=4073
NB8A schematic:
http://adaptronic.com.au/forum/index.ph ... ttach=4371
Adaptronic E420C loom components available
