Wolf3d tps issue 1.8 auto
motomenace
Postby motomenace » Thu Apr 18, 2013 3:36 pm
Hi,
I have a wold 3d v4 for na6. It plugs straight in to the 1.8 harness. I had it tuned at mx5 mania but the tps (variable type 4 pin connector) reads constant at 97%
David thought their was a wire to move or remove but couldnt remember. Its been tuned using map signal and runs great, but i want the tps to work as well.
I have read alot about 1.8 tps to 1.6 but cant seem to work out what i need to change to get the tps to read. Think i need to remove 1 wire to make it work but want to confirm before doing anything.
It seems this is a common question but cant get my head around it.
Someone out their knows the issue so thought id just ask.
Sorry if this has already been answered.
Re: Wolf3d tps issue 1.8 auto
Postby 93_Clubman » Thu Apr 18, 2013 6:18 pm
93_Clubman wrote:Not sure if this will help as it was for the the Wolf3DV4+ on an NA8, but Boyracer advised me if a TPS signal was not present to connect red/black from TPS to blue/red by swapping the position of the wires at the wiring loom ECU plug. Lou advised that on the NA8 at least you could do this because the blue/red did nothing. So for the NA8 on the 13 pin wiring loom ECU plug you switch the blue/red at bottom row position five from the left, to top row position seven from the left, where the red/black is, & then place the red/black into the now vacant bottom row position five.
viewtopic.php?f=29&t=45107&p=570436&hilit=wolf%2A#p570436
Users browsing this forum: No registered users and 225 guests
