Rear Demister
Gladiator
Rear Demister
Postby Gladiator » Sat Mar 23, 2013 4:54 pm
Can anyone tell me where the rear demister plugs into? My dash (NA) has the blank switches to the right of the steering column (wires but no switches). One of them must be for the demister. My new soft top has a demister, and being an electrical dunce to put it nicely, where is the wire?
What is this one?
Steampunk
Re: Rear Demister
Postby Steampunk » Sat Mar 23, 2013 6:06 pm
The only answer I can give you is you're correct, the switch is one of the blanks on the right. If you can't figure it out, don't stress cause I can't remember ever using my demister.
Re: Rear Demister
Postby 93_Clubman » Sun Mar 24, 2013 11:35 am
Have a quick look at the following - they should clarify your situation, but essentially wiring presence varied depending on year & market:
viewtopic.php?f=28&t=52517&p=660180#p660180
viewtopic.php?f=18&t=41368&p=531892#p531892
While this is for the hardtop it also covers demisters: http://www.miata.net/garage/hardtop/
Re: Rear Demister
Postby Hammer » Sun Mar 24, 2013 9:21 pm
Here's my post in retro-fitting a demister on my NA8 hardtop. Apart from the switch, you'll also need a relay and a fuse.
viewtopic.php?f=57&t=34566&start=15
