Right Turn Flasher Issue
zephyrus17
Postby zephyrus17 » Sat Feb 23, 2013 1:47 pm
For a long while, I've been having this issue where indicating right causes the ticking sound to be at 2x the frequency, but no light comes on. Left indicating is perfectly normal.
Today I diagnosed it, and found that even with hazard lights, the right bulbs front and back don't light up. Swapping the bulbs left to right at the front and back still don't light it up. So that eliminates the bulbs as the cause.
I pulled out the flasher unit like what the other threads and miata garage recommended. Here's a picture of the back-side. Could the upper right corner have a faulty solder? There's a black spot on the board and on the 2 nearest solder drops.
EDIT: Anyway I can get it resized?
Momo (aka 1990 white NA6)
Re: Right Turn Flasher Issue
Postby NitroDann » Sat Feb 23, 2013 7:14 pm
get your image code and tag swapped for this one.
Postby NitroDann » Sat Feb 23, 2013 7:16 pm
Any electronics repair shop mate.
zephyrus17
Postby zephyrus17 » Sat Feb 23, 2013 7:41 pm
Do they even do repairs these tiny stuff? I'll have a looksee around.. And anyway, MX5+ quoted me $16.5+shipping, so if nothing else, that'll work..
Postby NitroDann » Sat Feb 23, 2013 8:02 pm
Thats not tiny that normal person sized.
Its the robot sized ones on your phones mother board that are tiny!
Any electronics shop that fixes appliances can do it.
Postby Mr Morlock » Sun Feb 24, 2013 7:52 pm
just replace it - a repair is not going to be feasible. Or take it to an auto elec and get them to check and replace as required. Your car is not safe without a turn signal function.
noobee
Postby noobee » Sun Feb 24, 2013 8:37 pm
Mr Morlock wrote:just replace it - a repair is not going to be feasible.
Not so,if its just solder cracks its an easy fix.mine took about 3 mins to fix including waiting for the soldering iron to heat up.only rudimentary soldering skills are needed.
Mick
Postby hks_kansei » Mon Feb 25, 2013 5:37 pm
Depends on how simple/complex the NA flasher relay is.
When the relay on my NB started sticking I just replaced it, I think the replacement was only $5 or so (maybe $10?)
taminga16
Postby taminga16 » Mon Feb 25, 2013 11:12 pm
Hi, If the joint is black it's been hot, and for a reason, use it as sample in the purchase of a replacement and throw the offending item over your shoulder. F&$K, How much did you earn in your last hours work and how much time has this investigation cost?
Greg.
Users browsing this forum: No registered users and 221 guests
