Stuck speedo...
Silvia
Stuck speedo...
Postby Silvia » Tue Jan 22, 2013 1:59 pm
Was driving the NB for about 3km when I looked the speedo was reading zero kmh. As I pondered this it came free and works again.
I believe it is not cable dríven. The car was not used for 10 days so can this contribute to this by sticking somehow?
Silver Nomad
2002 NB8C
Re: Stuck speedo...
Postby KevGoat » Tue Jan 22, 2013 2:19 pm
My NA sometimes sits for a few weeks and no problems.
Maybe check the connections at gearbox/instrument panel.
I replaced my cable with a new one a short while ago for a possible noise issue - turned out not to be the cable though :( It was pretty cheap, so it didn't worry me too much and now I know its a new cable in there. Had I used some common sense and noted what route the cable took behind the dash from the firewall to the instrument panel, it would have been an easy 1/2 hour job....took me 2 hours and a damned sore back :oops:
Re: Stuck speedo...
Postby KevGoat » Tue Jan 22, 2013 2:22 pm
BTW ... I believe NB is electric, so no cable .... duh :roll: So just check sender unit & wiring for loose connections ...
Silvia
Re: Stuck speedo...
Postby Silvia » Tue Jan 22, 2013 3:30 pm
Glad you caught on to that one Kev :lol:
Silver Nomad
2002 NB8C
SalonRacing
Re: Stuck speedo...
Postby SalonRacing » Tue Jan 22, 2013 7:53 pm
It is probably just a bad connection on the back of the cluster, they have 3 ribbon style cables and it should be pretty obvious where the contact patches are that you can clean up.
If you haven't removed the cowl on top of the cluster there is a few threads about it, the clips can be a bit fragile.
Re: Stuck speedo...
Postby 93_Clubman » Wed Jan 23, 2013 10:15 am
KevGoat wrote:...took me 2 hours and a damned sore back :oops:
For any under dash work it's well worth removing the seat so you can lay on your back & even put your feet up on the rear shelf.
This seems to happen occasionally on NB8B:
viewtopic.php?f=29&t=42521
viewtopic.php?f=18&t=48128
The car in the second post was flood affected, & it's thought had an ECU problem as a result, as there was a bunch of things that went wrong with it & eventually forced the owner to off load the car.
Silvia
Re: Stuck speedo...
Postby Silvia » Wed Jan 23, 2013 4:57 pm
thanks,,,,I've emailed honki3rider mentioned above with a similar problem and I'll try jiggling the wire harness behind the dash..
Silver Nomad
2002 NB8C
Silvia
Re: Stuck speedo...
Postby Silvia » Thu Feb 28, 2013 5:16 pm
Just for the record - many owners in the States have reported this problem too(see Miata.net on how to fix it) http://forum.miata.net/vb/showthread.ph ... ost6211281
Briefly - the sender is screwed into the side of the gearbox. The two wires to the speedo join the sender ,soldered on and
filled with goop. Through heat and vibration the poor solder job comes adrift , and loses constant contact.The fix involves re-soldering and replacing goop. The pics make it look do-able..... :lol:
Silver Nomad
2002 NB8C
Re: Stuck speedo...
Postby Mr Morlock » Tue Mar 19, 2013 6:42 pm
Goop- is that an engineering term like "thingy".
Silvia
Re: Stuck speedo...
Postby Silvia » Tue Mar 19, 2013 7:35 pm
Closest thing I know of is tube silicon thingy. :roll:
Silver Nomad
2002 NB8C
zero00
Re: Stuck speedo...
Postby zero00 » Tue Mar 19, 2013 8:15 pm
Mr Morlock wrote:Goop- is that an engineering term like "thingy".
'GOOP' = 'geez, old owner problem' [relates to previous owner not current]
Roger D-SUNSHINE COAST
Re: Stuck speedo...
Postby Mr Morlock » Tue Mar 19, 2013 8:31 pm
I like that - the acronym for Goop- it will get recycled :lol:
taminga16
Re: Stuck speedo...
Postby taminga16 » Tue Mar 19, 2013 8:50 pm
Hey Silvia,
What news on the fix and be aware that not all Goop's are cable and non-ferrous metal friendly!
Greg.
Silvia
Re: Stuck speedo...
Postby Silvia » Tue Mar 19, 2013 9:22 pm
The job's on hold as the speedo has decided to function normally again....possibly cooler weather or I dunno what :roll:
But I feel confident to go for it should the problem recur.
Good point about the Goop.......I'll check with Jaycar and see what they say....
Silver Nomad
2002 NB8C
zero00
Re: Stuck speedo...
Postby zero00 » Tue Mar 19, 2013 9:33 pm
Mr Morlock wrote:I like that - the acronym for Goop- it will get recycled :lol:
Thanks MM!! Just sitting here thinking now I have to clean the rubber off my NB after Lakeside yesterday! Not as bad as the 86 guy who's white rocket copped rubber 'splats' all over the front
SPLAT: 'Special Protection Lacking At Track' :roll:
Users browsing this forum: No registered users and 62 guests
