A-Pillar Gauge Pod
spikes
A-Pillar Gauge Pod
Postby spikes » Mon Jan 07, 2013 1:36 pm
Hey guys, is anybody running gauges on the a-pillar? Want to share some pics and where you got them from?
There's tons of guys in the US running them in the LHD Miatas but I'm unsure if their LHD gauge pods can be flipped around and installed on a RHD car??
Steampunk
Re: A-Pillar Gauge Pod
Postby Steampunk » Mon Jan 07, 2013 1:40 pm
easily fine-able modification in Brisbane, you should find out if it's the same in NSW.
spikes
Postby spikes » Mon Jan 07, 2013 1:41 pm
Steampunk wrote:easily fine-able modification in Brisbane, you should find out if it's the same in NSW.
I still need to look into all the rules of modifications in NSW. My 5 will be getting engineered after the engine swap and turbo is done but
Postby Magpie » Mon Jan 07, 2013 1:49 pm
spikes
Postby spikes » Mon Jan 07, 2013 1:56 pm
In my personal opinion, I think those style pods are really ugly.
Postby Magpie » Mon Jan 07, 2013 3:14 pm
spikes wrote:In my personal opinion, I think those style pods are really ugly.
I agree they are ugly.
Hjt
Postby Hjt » Mon Jan 07, 2013 3:21 pm
They are illegal in NSW and cannot be engineered. Sorry mate.
spikes
Postby spikes » Mon Jan 07, 2013 3:31 pm
Hjt wrote:They are illegal in NSW and cannot be engineered. Sorry mate.
ƒü¢k
dave2221
Postby dave2221 » Mon Jan 07, 2013 4:14 pm
So wrong
they are not illegal at all!
On a NB, from my correspondance with the RTA Tech dept.
Because it would be mounted behind the steering wheel, and below the line of sight over the dash its fine!
If ANYONE can please prove me wrong ill eat my hat.
The ADRs concerned deal with hitting your head in an impact (not possible if mounted low on the a pillar) and also deals with line of sight (again not possible if mounted low on a pillar)
Cars like a 200sx, where its generally mounted higher, usualy in front or level with the steering wheel pose both collision risk and sight risk, thus on many cars it is illigal.
But not on a MX5 if mounted low.
here is a copy past from Technical_Enquiries@rta.nsw.gov.au dated 16/03/2012
David. 1 The RTA have no regulation that require a shift paten for a manual transmission.
2 Internal sun visors are required under ADR 11.
3 A gauge can be mounted to the right side of the steering wheel and no higher than the steering wheel.
Regards Kevin.
Now, i disagree with point 2, as ADR 11 doesnt say sun visors are required, it just says how to build them....... so really, this i guess could be wrong, but i will add that i personally HAVE READ the ADR in question...... but basically, there is no reason why you couldnt stick a gauge pod on the pillar
Postby Hammer » Mon Jan 07, 2013 4:17 pm
spikes wrote:Hey guys, is anybody running gauges on the a-pillar? Want to share some pics and where you got them from?
No! LHD gauge pods cannot be flipped onto RHD. You need to get a RHD specific pod.
Have you tried contacting MX5 Mania - http://www.mx5mania.com/product1665.htm
spikes
Postby spikes » Mon Jan 07, 2013 4:36 pm
dave2221 makes a good point, I have mates with S14s and other silvias and they have a single gauge pod on the a-pillar for their boost gauges, came factory like that or something..
Reading ADR rules now..
Hjt
Postby Hjt » Mon Jan 07, 2013 4:45 pm
It's illegal because its higher than the steering wheel. As you mentioned above.
Muzdaman
Postby Muzdaman » Mon Jan 07, 2013 5:10 pm
spikes wrote:dave2221 makes a good point, I have mates with S14s and other silvias and they have a single gauge pod on the a-pillar for their boost gauges, came factory like that or something..
I believe Aus S15s had the gauge pod removed to meet ADRs. as long as you mount it low and as far back as you can it wont be a problem.
If you buy a mounting cup and mount that to the existing pillar trim you can mount it as far back and as low as possible.
Postby bruce » Mon Jan 07, 2013 5:43 pm
Ask Lokiel. He's gone through all this and got some.
Steampunk
Postby Steampunk » Mon Jan 07, 2013 8:15 pm
JDM S15's had them standard and I've no idea what loophole they used, but if a car came with them they are ok with the law because it's OEM.
ADM S15's did not have them removed, as they were never fitted from the factory.
I've never seen any standard S14, JDM or ADM with them standard.
