motorised aerial in a NA6
Hi guys just wondering if any1 knows of a good motorised aerial to put into a NA6? one that would be a simple takeout of old and replay of new... if that can be done but let me know what uz know.. thanks
- KevGoat
Re: motorised aerial in a NA6
No wiring in place for power aerial in a NA6 so not just a remove/replace scenario. I have seen them fitted but didn't look straight forward. Some cutting required.
Yeah nee I would need to wire it up... but don't rly want to cut anything.....
- Jeo
How about the one that came in the JDM NA6?
My sons JDM NA6 / Eunos Roadster has one but you have to press a button to raise/lower it, not sure if it was factory fitted seems aftermarket to me.
- Jeo
Mine was automatic with the radio and it looks remarkably factory. I've seen other NA6's with the same aerial so I assumed it was standard. My car is a V Special though so maybe it was an added extra?
That's about the best photo I can find of it sorry.
so ther is hope then... its good to know that the NA6 may have come out with 1... i may need to look around and see if i can pick up one... if any1 finds 1 cheap let me know or.. if any aftermarket 1 that doesnt need me to cut anything would be great.
late model jap NA6's had a motorised aerial, comes up automatically with the radio; so the part does exist, but those cars have the wiring in place to run them, so if you do find the aerial, you will have to adapt/modify/create control wires for it.
Totally possible, but if you didnt want to "cut anything" then its probly a waste of time.
Just get one of these, they are 100% plug and play and look great!
- bruce
- Vehicle: NA8 - Turbo
Yes, Australian NA6s won't have any wiring. Just fit a stubby aerial.
thanks for all the replys i will have a look around and see what i can turn up
Users browsing this forum: No registered users and 61 guests
