NC fault codes
Posted: Tue Dec 04, 2012 10:51 am
by Regie
After the track day on the weekend, my car is sometimes throwing up a code and failing to start. The code is:
U0101 - Communication error to TCM
Does anyone know where the traction control module is on the nc?? First call wold be to check the connection on the plug
Re: NC fault codes
Posted: Tue Dec 04, 2012 12:19 pm
by JBT
Re: NC fault codes
Posted: Wed Dec 05, 2012 5:48 am
by Regie
Looks like its sorted now.
Posted up on the big forum also, they linked me to a Mazda service bulletin. Apparently having anything plugged into the obd port can shoot up random codes....so the scan gauge is now unplugged and no codes have been thrown up
Re: NC fault codes
Posted: Wed Dec 05, 2012 8:07 am
by neilhr
Oh ok i have my dashdaq plugged permanently into obd, never seen any odd cels
Re: NC fault codes
Posted: Fri Dec 28, 2012 10:34 pm
by TieNN89
Regie wrote:Looks like its sorted now.
Just saw this thread I was going to ask if anything was plugged into the OBD port
Mine had lights flashing all over the dash when the Scangauge got hot sitting in the sun when I mounted it above my rear view mirror.
It has also scared the panel shop a few times when I've taken it there and then the CEL starts appearing.
We can only put it down to the Scangauge not being able to handle the heat from the car sitting in the paint booth.
Re: NC fault codes
Posted: Sat Dec 29, 2012 12:26 pm
by Regie
I pulled the scangauge apart, one of the connector solid wires was broken. ill get around to fixing It one day
