aftermarket head unit with bose amp?
magenb
Postby magenb » Fri Sep 14, 2012 7:32 pm
I've been searching all over the place for a guide on replacing the stock head unit. I've found a mass of DIY removal instructions and tib bits here and there in various forums all over the place.
Has anyone found a guide on connecting an aftermarket head unit to the bose amp?
Re: aftermarket head unit with bose amp?
Postby NitroDann » Fri Sep 14, 2012 9:27 pm
4 channel amps can be had for as little as 100 dollars, I cannot imagine, unless there is a patch loom or simple diy, that it is worth trying.
bear2230
Postby bear2230 » Sat Sep 15, 2012 8:46 pm
:BROADY:
Dump the Bose amp. They're crap.
timk
Postby timk » Sun Sep 16, 2012 1:47 am
The impedance is really weird too, it's not standard stuff (including speakers).
magenb
Postby magenb » Mon Sep 17, 2012 10:58 am
NitroDann wrote:4 channel amps can be had for as little as 100 dollars, I cannot imagine, unless there is a patch loom or simple diy, that it is worth trying.
Yeah I've gone down that path before, PITA to mount it and cable it all correctly, I'd rather just solder a few wires :)
timk wrote:The impedance is really weird too, it's not standard stuff (including speakers).
Yeah I've read the same thing which is why I was looking for a guide :)
bear2230 wrote::BROADY:
I'm only changing the headunit to get USB/MP3 support, I don't have a problem with the sound volume or quality its putting out now.
Postby NitroDann » Mon Sep 17, 2012 11:15 am
Does the bose amp have rcas?
Or an rca level input?
bear2230
Postby bear2230 » Mon Sep 17, 2012 6:17 pm
NitroDann wrote:Does the bose amp have rcas?
Naa Dann, there is 2 pissy little amps stuck under the dash about the size of a packet of ciggies. I think 1 is for the mids and 1 for the tweeters. Would be heaps easier to just connect the wires.
Give it a crack yourself or drop it to a shop. It won't take them long to sort.
Richard.
Users browsing this forum: No registered users and 221 guests
