Advice please - NC - Lighting up my footwell.
poverty rider
Postby poverty rider » Wed Sep 12, 2012 8:47 pm
The plan: To install LED strips under the dash to illuminate the footwells when the doors are opened.
Each door would only activate its corresponding lamps. Blue and lilac seem to have a nice ambience - and a nice price on 'fleabay'.
A master On/Off switch would be a thought as I like to leave the doors open, after washing, to drain.
What I need: Lots and lots of advice. I've only had this car for a month and I don't know my way around it yet. So, before I blindly dive in head first, I'd like to hear from some of the 'tinklers' out there who can give me some tips, tricks, warnings, ideas, and advice on tackling my project.
taminga16
Re: Advice please - NC - Lighting up my footwell.
Postby taminga16 » Wed Sep 12, 2012 11:45 pm
Hi Brian,
I have done this. I used some generic LED's from Jaycar (3 in each solid state unit) and the rest is easy, a constant active is found in the fuse box adjacent to the passengers feet and the earth is from the passenger side door switch, the door switches are closed to earth and as such you will not be able to have the foot lamps operate independently.
HOW TO.
Remove the trim from the passengers rear door pillar to expose the door switch.
Remove the sill trim.
Remove the passenger side kick panel (Carefully so as not to break the push centre clips).
Using a scotch lock type connector join a cable (2.4m) to the one that exits the back of the switch this will be the earth in your circut.
Run the cable along the door sill, behind the kick panel and under the dash to the first lamp position, I mounted mine above the transmission turrent, leave a loop of cable to work with and then continue to the next position, leaving the cable tail.
Locate a constant active in the fuse block above the pasengers feet, there are a number of ways of attaching a cable here, but a piggy back fuse is the easiest (an auto electrician should have one, 3 amp is perfect and it will act as your in line fuse safety). DO NOT CONNECT THE POWER YET.
Run this cable to the first lamp position, leave a loop to work with and continue on to the second lamp.
Connect your lamps and if you do use LED's remember that they are polarity sensitive (ie +to+, -to-).
I soldered all of my joints but crimping is fine (you can twist and check your circut if you like) ensure that there are no exposed ends, attach the power side open and close both doors to check operation and if all is OK, secure your new cabling out of the way where it cannot rub on anything. leaving the lamps to hang for now.
Refit all of the trim, again making sure that nothing will rub.
Wait until dark and tune the position of the lamps to suit and then secure them into place with a cable tie.
The image show the LED's wired in series but you can just cut them off as required, think about which end you cut so as not to waste the last one, I also installed an extra lamp in my boot, in the centre and above everything.
Greg.
PM me if you get stuck. Oh, and if you are up to it you could also install a lamp into the glove compartment, using the same active, a micro switch (need to drill a hole and a different earth).
I have just re-read your post, If you need a master switch the best placement is in the active side, ie; at the fuse panel but LED current draw is minimal anyway, once you install them you will be shopping for an LED insert for the overhead light just to match the colour :) .
taminga16
Postby taminga16 » Thu Sep 13, 2012 12:28 am
CURCUIT,CURCUIT,CURCUIT, forgive my spelling.
Greg.
And if this is to stay could some kind soul please correct my spelling so that I do not die appearing an ignorant fool who cannot spell. :frown: My post will be riddled with it.
Postby bruce » Thu Sep 13, 2012 3:32 pm
Circuit
taminga16
Postby taminga16 » Thu Sep 13, 2012 6:09 pm
bruce wrote:Circuit
Thanks Bruce, it's nice to know that my middle of the night humour wasn't wasted. :)
Greg.
Users browsing this forum: No registered users and 263 guests
