What electrical connectors to use?
Posted: Sat Jul 28, 2012 7:06 pm
Hi all
Just after some information / recomendations for people. I have a few aftermarket bits and pieces that require wiring of some sort or another. I would rather not use typical crimp connectors as ive had issues with these in the past ( possibly due to using cheap plugs / crimping tool ), also soldering isnt ideal as i have no power where the car is.
I'd like to have each component have its own "harness" with the ability to disconnect when needed. Connectors dont need to be waterproof but it's a ncie bonus. Ill pick up some nice marine grade electrical tape to wrap things as needed.
I thought something like http://www.ebay.com.au/itm/Kit-2-Pins-Waterproof-Electrical-Wire-Connector-Plug-/130725261436?pt=LH_DefaultDomain_15&hash=item1e6fd5307c
OR
http://solutions.3m.com/wps/portal/3M/e ... 2NDGZBTHgl
If i want to tap into something / share a power or gound.
Any opinions / recomendations?. Ideally under $2 a connection would be great, that gives some room for not expensive error
Id love some reading material if anyone knows some good sources on how to use the above connectors if they are ok.
Thanks
Scott
OR
Thanks
Scott
