Didn't get too much info when posted elsewhere, so we'll see whether the techies have an answer?
I have put an aftermarket demister on our NA hardtop which is on a 2002 NB8B. I'm having trouble working out the wiring. I've done a search on the is forum and Miata.Net for an answer, and I can't seem to find one.
Now I'm aware of the cutoff switch which disables the demister when the softtop is down - I presume this is on the car side of the connector? I think this is where my problem is. I couldn't get hold of an NB demister plug and loom (softtop side) so I have replaced the plug with a different 3 pin one from Jaycar. I've had a look at my softtop wiring, and the black / white stripe wire doesn't appear to go anywhere - it perhaps just ends inside the loom cover somewhere? Certainly there's only the black and black / red wire which actually connects to the demister that I can see.
So, where does the black/white wire go to on the demister side? If nowhere, then presumably my problem is that the softtop down cutoff switch is stopping the demister working, so how do I bypass / fix this? BTW I checked the demister light came on with the softtop up, so the circuit is working
Presume someone else has had this problem???
Any help appreciated
Two Heads
Hard Top demister wiring
