B6 and BP CAS interchangeability
Posted: Fri Jul 20, 2012 7:48 am
by plohl
Hey,
Just to confirm, (pretty sure they are interchangeable) are the B6 and BP CAS (Crank/cam angle sensor) able to be swapped between the engine platforms?
:beer:
Re: B6 and BP CAS interchangeability
Posted: Fri Jul 20, 2012 6:29 pm
by plohl
No can confirm this :(
Posted: Fri Jul 20, 2012 6:58 pm
by Dweezle
HI Mate,
just by chance i stumbled across this page.
It seems to say the CAS is interchangable.
http://www.jspecauto.com/files/jspecautotechcenter5b.htm
Since the 1.8 is really just a stretched 1.6, most everything on the front and back of the motor will interchange between the them. This includes the cam angle sensor, coolant intake pipes, flywheel/clutch assembly, various covers and brackets, cam gears, water pump, and timing belt tensioner, etc.
Posted: Fri Jul 20, 2012 7:51 pm
by plohl
Thanks very much dude!
Posted: Fri Jul 20, 2012 8:15 pm
by timk
I know Geoff (sabretooth) was using a B6 CAS on his BP.
Posted: Sat Jul 21, 2012 9:07 am
by plohl
Yeah, i am pretty sure sailaholic has a B6 one in his BP too
Posted: Fri Aug 03, 2012 3:20 pm
by Sean
Yep.
I put a BP one into a B6 ages ago.
It's a mitsu part and can also be substituted with some 4 cyl mitsu's (Early EVO from memory).
