Hey guys,
I've been thinking of starting a project using either an Arduino with WiFi or a Raspberry Pi with a USB WiFi dongle.
Both these devices have GPIO pins, but it looks like the Raspberry Pi lacks analog inputs so it may not a good choice.
The plan is to convert the TPS voltage and the RPM pulses into digital signals, and emulate an ELM327 presented via WiFi.
Harry's LapTimer should then be able to grab data from it.
Very early stages, just seeing what you guys think?
Getting TPS and RPM into Harry's LapTimer without OBD2
- timk
- plohl
- Zcootz
Re: Getting TPS and RPM into Harry's LapTimer without OBD2
Have you looked at the Pic processors ? They have A/D converters built in. I knocked up a shift light for my rally car with a Pic and worked out the revs by timing the spark, a friend wanted one for a Wrx which was much easier as it had a nice 5v clean tacho drive signal to work from. Hopefully the mx5 has a simar signal.
The Rasberry PI may be a problem with supplies, I've been told I've got to wait another 6 weeks for mine and that they are only shipping one off's due to a policy to widen the distribution.
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Murray Walker
Users browsing this forum: No registered users and 258 guests
